Fixed it for youweblord wrote: 15 May 2018, 15:54 i still have problems with migrator.phpCode: Select all
Catchable fatal error: Argument 1 passed to phpbb\db\migrator::get_callable_from_step() must be of the type array, null given, called in /home/www/paidpost.nabaza.com/phpbb/db/migrator.php on line 704 and defined in /home/www/paidpost.nabaza.com/phpbb/db/migrator.php on line 726Solidjeuh wrote: 14 May 2018, 15:17 Thank you for the fix! migrator.php problem is solved now.
Installed & uninstalled without a problem!
3.2 & 3.3 Extensions Database 3.2 / 3.3 ⇒ Ultimate Points Extension
Re: Ultimate Points Extension
weblord
Thank you very much!
yo da man
yo da man
dmzx wrote: 15 May 2018, 16:30Fixed it for youweblord wrote: 15 May 2018, 15:54 i still have problems with migrator.phpCode: Select all
weblord
What would you do if you like 8 decimal points for this? i only can see two decimal points.
Tarantino
Its still full of old problems already reported here :(
But well I've fixed mine, so I dont mind, but just to inform.
Yes thanks see your post will look into that, thanks again to mention itTarantino wrote: 18 May 2018, 12:33 Its still full of old problems already reported here :(
Voice4Vision
Thank you for such an awesome extension dmzx! I have your latest release 1.2.0 installed and was pleasantly surprised at the additions. I understand that the development is tedious and time-consuming, however I come with some suggestions that might make the Ultimate Points Extensions a bit more purposeful.
Besides the more commonly requested Shop extension, as much as I would love to see one, I personally can not envision how it can be used. Unless there was a way to make it integrate with phpbb permissions in which certain site features could be "turned on" (enabled) after purchasing.
My suggestions is more to expand on the Ultimate Points Extension...
Multiple Currency with Conversion Ratings. So say our currency names are bronze, silver, and gold. It could take 100 broze to make 1 silver, or 1000 silver to make 1 gold. etc. Conversion ratings could be a variable with an established range or based on member needs and uses. I.E. if gold is won or used most, then gold stocks increase, whereas the least used currency is declined within a given time frame.
Multiple currencies could also play an significant role with banking, robbing, and the lottery.
Different bank accounts for each currency
You can only rob 1 currency with a chance to score a robbery of another currency at smaller odds. Maybe based on past success. i.e you successfully rob member "A" 3 times, you have a chance for a additional steal of a random currency at 10% odds.
Lottery can only play with 1 currency. i.e. you pay with bronze, you can only win bronze. Each currency would have its own stats and jackpot. Instant Announcements for large jackpots that sets new record of winnings.
The Stock Market - Is strictly based on admin settings, either according to member use or random variables with minimum and maximum inflations/deflations.
Jail - You get caught stealing, you pay your price. Victim gets a % of your currency. If thief pays his bail, his bail price gets added to the lottery. Bail price is 10 times of what he had to pay his victim. If thief does not pay his bail, his punishment is reduced permissions at a set time frame. i.e. can not post, banned from lottery, etc
Just a few more ideas...I have many more, but I feel this maybe overwhelming all in itself.
Thank you for taking the time to read over these ideas.
Voice4Vision
Voice4Vision
Kakagawa
Hello from Ukraine, dmzx. I want to say thank you for this amazing extension, you solved an important problem of my project. Now it is frozen, because it requires something like UPS Easy Shop but for 3.2.x. whether something like this is planned for 3.2.x?
Will update soon some fixes.
Out now for the weekend.
Kakagawa
This is very great news, thank you! I'l be waiting!
When i try to enable this ext i suspect following error
message on the picture means: This page does not work
Test.kefcheto.eu is currently unable to process this request.
i test this ext on my test board
i can't enable it
i can't enable it
EaglesTruth
Still get the same fatal error that i reported earlier. i cant even uninstall, i have to do it manually in the database. still doesnt work
Pm me admin account and link to your board.EaglesTruth wrote: 19 May 2018, 23:38 Still get the same fatal error that i reported earlier. i cant even uninstall, i have to do it manually in the database. still doesnt work
