3.2 & 3.3 Extensions Database 3.2 / 3.3Download System
moffacostanzo
    Mac OS X Firefox
Re: Download System
Post by moffacostanzo »
I have this error
Errore Generale
SQL ERROR [ mysqli ]
Unknown column 'announce_lock_enable' in 'field list' [1054]
SQL
UPDATE phpbb_dm_eds_config SET pagination_acp = 5, pagination_user = 3, announce_enable = 1, announce_forum = 45, announce_lock_enable = 0, pagination_downloads = 25
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 855
CALL: trigger_error()
LINE: 193
LINE: 329
FILE: [ROOT]/ext/dmzx/downloadsystem/controller/admin_controller.php
LINE: 219
CALL: phpbb\db\driver\factory->sql_query()
FILE: [ROOT]/ext/dmzx/downloadsystem/acp/downloadsystem_module.php
LINE: 39
CALL: dmzx\downloadsystem\controller\admin_controller->display_config()
LINE: 674
CALL: dmzx\downloadsystem\acp\downloadsystem_module->main()
FILE: [ROOT]/adm/index.php
LINE: 81
CALL: p_master->load_active()
Re: Download System
moffacostanzo wrote: 11 Dec 2016, 20:57 i have this error
Errore Generale
SQL
BACKTRACE
CALL: msg_handler()
LINE: 855
LINE: 193
LINE: 329
LINE: 219
LINE: 39
LINE: 674
LINE: 81
Did you correctly update the extension?
moffacostanzo
    Mac OS X Firefox
Re: Download System
First i have this problem when instal ext appears this error
Re: Download System
moffacostanzo wrote: 11 Dec 2016, 21:04 first i have this problem when instal ext appears this error
So are you updating from version 1.0.0?
moffacostanzo
    Mac OS X Firefox
Re: Download System
No
i remove an ext
because i do't have download
and i install e new version
i used e version 1.0.2
Re: Download System
moffacostanzo wrote: 11 Dec 2016, 21:06 no
i remove an ext
Ok check you ACP for left over download system modules and delete them manual. (disable and then delete them)
After that install v1.0.5 again.
See below where to find the module.
moffacostanzo
Re: Download System
Ok i reinstall en ext
i create a category but if i set anable a announce new download appears this one
Errore Generale
Column 'topic_desc' cannot be null [1048]
SQL
INSERT INTO phpbb_topics (topic_poster, topic_time, topic_last_view_time, forum_id, icon_id, topic_posts_approved, topic_posts_softdeleted, topic_posts_unapproved, topic_visibility, topic_delete_user, topic_title, topic_first_poster_name, topic_first_poster_colour, topic_type, topic_time_limit, topic_attachment, topic_status, topic_desc) VALUES (2, 1481490428, 1481490428, '45', 0, 1, 0, 0, 1, 0, 'Informatica per grandi e piccoli', 'costanzo', 'FF8000', 0, 0, 0, '0', NULL)
BACKTRACE
CALL: msg_handler()
LINE: 855
LINE: 193
LINE: 329
FILE: [ROOT]/includes/functions_posting.php
LINE: 1934
LINE: 2022
CALL: submit_post()
LINE: 873
CALL: dmzx\downloadsystem\controller\admin_controller->create_announcement()
LINE: 79
CALL: dmzx\downloadsystem\controller\admin_controller->add_new()
LINE: 674
LINE: 81
Unantastbar
Re: Download System
Post by Unantastbar »
Thx for the Update, it works fine on my Testforum. :thumbup:
iorG19
Re: Download System
Post by iorG19 »
It's possible to have parent categories ?
Re: Download System
iorG19 wrote: 19 Dec 2016, 15:34 it's possible to have parent categories ?
No at this moment not, maybe future... cannot say.
iorG19
Re: Download System
Post by iorG19 »
dmzx wrote: 19 Dec 2016, 15:45
and what about attachment quota (posibility to set maximum attachment file per file and global per user: in bytes, or kilobytes) and extension types (.xml, .rar, .pdf,...) :oops:
Re: Download System
iorG19 wrote: 19 Dec 2016, 15:49
See here for allowed_extensions https://github.com/dmzx/Download-System ... r.php#L635 you can add them also if not listed.
Remember to do it also in edit part of same file.
Maximum attachment size depends on php upload_max_filesize settings and can only be changed there.(for all type of files so not independent)
iorG19
Re: Download System
Post by iorG19 »
I wonder how to add lines for (default) topic. Let me explain; i want to change this:
we have a new download!
Title: [b]%1$s[/b]
Description: [b]%2$s[/b]
Category: [b]%3$s[/b]
Click [b]%4$s[/b] to go to the download page!
to this:
[color=purple][size=120][b]Title:[/b][/size][/color] %1$s
[color=purple][size=120][b]Author:[/b][/size][/color] %2$s
[color=purple][size=120][b]Description:[/b][/size][/color] %3$s
[color=purple][size=120][b]Category:[/b][/size][/color] %4$s
[color=purple][size=120][b]Requirements:[/b][/size][/color] %5$s
[color=purple][size=120][b]Click[/b][/size][/color] [i]%6$s[/i] to go to the download page!
But i don't know if it's correct; i mean if you need to add some sentences. Cheers!
Re: Download System
Yes you can do like that.
Re: Download System
