3.1.x SnippetsCollapse in 3.1.x
Snippets
Magic user status: Online
Collapse in 3.1.x
Collapse in 3.1.x
Thanks to martin for below code.
Note this hacked into core files i cant see why any one would want an ext for some thing that will always be turned on.
Open: /styles/prosilver/template/forumlist_body.html
<!-- BEGIN forumrow -->
Add before Add these lines on a new blank line before the preceding line(s) to find
<div class="forumlist">
<!-- IF (forumrow.S_IS_CAT and not forumrow.S_FIRST_ROW) or forumrow.S_NO_CAT  -->
            </ul>
</div>
<ul class="topiclist forums">
<!-- IF SCRIPT_NAME eq 'index' --><div class="trigger active"></div><!-- ENDIF -->
            <div class="collapsethis">
<!-- IF forumrow.S_LAST_ROW -->
            </ul>
</div>
<!-- END forumrow -->
</div>
Open: /styles/prosilver/theme/common.css
.dropdown .clone.hidden + li {
	border-top: none;
.trigger {
    background: url("./images/collapse-icon.png") no-repeat;
    width: 32px;
    height: 17px;
    cursor: pointer;
    float: right;
    position: relative;
    z-index: 9998;
    margin-top: -21px;
.active {background-position: left top;}
.inactive {background-position: left bottom;}
Open: /styles/prosilver/template/overall_footer.html
<!-- IF S_PLUPLOAD --><!-- INCLUDE plupload.html --><!-- ENDIF -->
<script type="text/javascript" src="{T_TEMPLATE_PATH}/jquery.cookie.js"></script>
<script type="text/javascript" src="{T_TEMPLATE_PATH}/jquery.collapse.js"></script>
        $(".forumlist").collapse({show: function(){
                this.animate({
                    opacity: 'toggle',
                    height: 'toggle'
                }, 300);
            hide : function() {
                this.animate({
                    opacity: 'toggle',
                    height: 'toggle'
                }, 300);
</script>
collapsible-categories(8).zip
Copy the .js files to template folder and the .png file to theme/image folder.
Now purge the cache and clear your browser.
Re: Collapse in 3.1.x
Screens shots for code above
If you want the collapse on other forum headers then use this
<!-- IF SCRIPT_NAME eq 'index' or 'viewforum' or 'viewtopic' --><div class="trigger active"></div><!-- ENDIF -->
Screenshot of viewforum
Demo click to see how it looks with the above code out side of the index page
testing
Post by testing »
I don't understand what is it, can you show a screenshot?
Screenshots added.
testing
Post by testing »
Thanks! That will be saved if the player will logout?
Its cookie based.
Logout and see.
Yes until you clear your browser's cache it will stay as you left it.
testing
Post by testing »
Awesome.
Sycron
Post by Sycron »
For 3.0.12 ? :D
Sycron wrote:For 3.0.12 ? :D
No this is for 3.1.X for 3.0.12 and below use this Collapsible Categories with Cookies - Christian Bullock
Sycron
Post by Sycron »
Thx
Allen42
    Windows 7 Internet Explorer
Post by Allen42 »
The expandable/collapsible is working on forums at the 3.1.2 version, so it works well without an extension! :)
How would you install this?
As i said in another topic i dont see the point of an ext for some edits it's not like your ever going to turn of the collapse is it :question:
But thats just my view.
Might make it into a switch
spaceace
Post by spaceace »
Very nice. thank you :grin:
