3.1 & 3.2 3.1.x SnippetsRainbow effect on username
Snippets
Magic user status: Online
Its done in css you can add it also.
I would recommend to use this extension Css magic 1.0.7 last version and add the css there.
This is the code:
a[href$="&u=55"] {
   -webkit-animation: rainbow 4s infinite;
animation: rainbow 1s infinite;
The u=55 is the user_id so change that to something else will give a other member the animation.
grtz dmzx
moffacostanzo
Re: Rainbow effect on username
Post by moffacostanzo »
Thank you
blackvampire
Post by blackvampire »
Scusate ma dove lo devo copiare in codice ???
moffacostanzo
    Android Firefox
Installi l ext css magic e poi inserisci il codice nel file css che trovi nello style/theme dell estensione
blackvampire
Ce lo installato il cssmagic ma quando copio il codice all interno non succede nulla
moffacostanzo
Hai inserito il tuo ID
blackvampire
Si
Keep it English pls so others can help also. :wink:
Tip: To add multiple users in the rainbow effect, add other user ids in the same line like this...
a[href$="&u=55"], a[href$="&u=62"], a[href$="&u=105"] {
blackvampire
Ok grazie 1000 ho risolto riguardo alla scritta ma il mio problema ora e come far funzionare il bot mchat
rammstein
Post by rammstein »
I installed the cssmagic but when I copy the code inside nothing happens I put the id 2 because it's me?
I added in the cssmagic
a[href$="&u=2"] {
I installed in the cssmagic
Add this:
a[href$="&u=2"] {
@-webkit-keyframes rainbow {
0% { color: #F00 }
17% { color: #FF0 }
33% { color: #0F0 }
50% { color: #0FF }
67% { color: #00F }
84% { color: #F0F }
100% { color: #F00 }
@-moz-keyframes  rainbow {
0% { color: #F00 }
17% { color: #FF0 }
33% { color: #0F0 }
50% { color: #0FF }
67% { color: #00F }
84% { color: #F0F }
rammstein
Post by rammstein »
A big thank you dmzx
I have a quick question how did you get that kind of snow on your nickname
rammstein wrote: Jan 21st, '18, 10:26 a big thank you dmzx
Therfore I added:
a[href$="&u=2"]:not([href*="compose"]):not([title*="Visit"]):not(.prof) {
  background: transparent url("https://www.dmzx-web.net/upload/uploads/1a7d80ca2cfc93d172bfd72967882ab3.gif") repeat-x scroll left top / auto 40px;
You have place correct url for the gif on your server.
rammstein
Post by rammstein »
:thumbup: thank you it's great dmzx :wink: :wink:
