3.1.x SnippetsSanta hat +
Snippets
Magic user status: Online
Santa hat +
All credits to martin
Here is how i have done the santa hat plus the falling snow.
Open style/prosilver/template/ html files (also ext html files) and
Find This may be a partial find and not the whole line (spaces may differ)
<div class="forabg">
Add before Add these lines on a new blank line before the preceding line(s) to find
<!-- IF SWITCHES_ENABLE_FIRST -->
<div style="position: absolute; margin: -5px 0 0 -18px;">
        <img src="{ROOT_PATH}images/cornerhat.png" alt="Santa hat" />
    </div>
For the logo bar i use a bigger image
Open overall_header.html
<div id="page-header">
<div style="position: absolute; margin: -12px 0 0 -48px ">
    <img src="{ROOT_PATH}images/cornerhatbig.png" alt="Santa hat" />
</div>
play with the numbers to fit the hat on your theme -5px 0 0 -18px
For snow
Open prosilver/template/overall_footer.html
</body>
<!-- IF SWITCHES_ENABLE_SECOND -->
<!-- INCLUDE snow.js -->
EXTRACT THE ZIP AND UPLOAD
root(13).zip
Your need to install this ext to have them on a switch (see first image on how to set up)
downloadsystemcat?id=26
Re: Santa hat +
I thought i posted this here ?
Condor
Re: Santa hat +
Post by Condor »
Very good job ! it works perfectly. :tumbsyes:
Thanks.
K3JAE
Re: Santa hat +
Post by K3JAE »
I seem a bit confused here...
In the instructions it states to open Open style/prosilver/template/ html files (also ext html files).
What specific HTML file(s) are we referring to? Or is this in ALL the files?
Also when I attempted to DL the ROOT extension it failed on the upload noting the composer.json wasn’t found in the uploaded zip file. :question:
Re: Santa hat +
K3JAE wrote: Jul 7th, '16, 19:26 I seem a bit confused here...
Choose only the html files you want the hats to show on.
As for composer.json, I don't know :(
K3JAE
Re: Santa hat +
Post by K3JAE »
I figured it out a few hours after posting this... Sorry, I should have returned and noted resolved. My oversight due to being busy doing multiple things at once.
Unantastbar
Re: Santa hat +
Post by Unantastbar »
Hey dmzx & martin,
big thx for this Snippet. :tumbsyes: I added this on my Forum. :wink:
zardos
    Ubuntu Firefox
Re: Santa hat +
Post by zardos »
Would this work on 3.2 or is it just for 3.1
Re: Santa hat +
Both :whistl:
zardos
    Ubuntu Firefox
Re: Santa hat +
Post by zardos »
:tumbsyes:
VikViku
Re: Santa hat +
Post by VikViku »
zardos wrote: Dec 5th, '16, 22:54:tumbsyes:
I uploaded images and added in forum_list, cleaned cache but nothng appears. :wtf:
Re: Santa hat +
VikViku wrote: Dec 7th, '16, 20:54
Did you install extension also?
VikViku
Re: Santa hat +
Post by VikViku »
dmzx wrote: Dec 7th, '16, 20:58
The problem that I uploaded to ext, changed the name of category from "Switches-master" to "Switches" but there was no extension in acp to enable...
Re: Santa hat +
VikViku wrote: Dec 7th, '16, 21:12
Folder must be ext/dmzx/switches and files in folder switches
VikViku
    Mac OS X Safari
Re: Santa hat +
Post by VikViku »
Case-sensitive. I see. Thanks.
