3.1.x SnippetsFile Download & Downloadlog extenion combination
Snippets
Magic user status: Online
If you have File Download and Downloadlog extensions installed this is how to combine them:
Open ext\dmzx\downloadlog\styles\prosilver\template\event\attachment_file_prepend.html
Delete Remove the preceding lines
<!-- IF _file.S_IMAGE -->
	<dl class="filedoawnload">
		<dt class="attach-image"><img src="{_file.U_INLINE_LINK}" class="postimage" alt="{_file.DOWNLOAD_NAME}" onclick="viewableArea(this);" /></dt>
		<!-- IF _file.COMMENT --><dd><em>{_file.COMMENT}</em></dd><!-- ENDIF -->
		<dd>{_file.DOWNLOAD_NAME} ({_file.FILESIZE} {_file.SIZE_LANG}) {_file.L_DOWNLOAD_COUNT}</dd>
	</dl>
<!-- IF _file.S_FILE -->
	<dl class="filedownload">
		<dt><!-- IF _file.UPLOAD_ICON -->{_file.UPLOAD_ICON} <!-- ENDIF --><a class="postlink" href="{_file.U_DOWNLOAD_LINK}">{_file.DOWNLOAD_NAME}</a></dt>
		<dd>({_file.FILESIZE} {_file.SIZE_LANG}) {_file.L_DOWNLOAD_COUNT}</dd>
		<dd><!-- IF (U_MCP or U_ACP) --><a href="{U_DOWNLOADLOG}?file={_file.U_FILE_ID}" onclick="popup(this.href, 950, 350); return false;"	title="{L_DOWNLOADLOG_VIEW_LOG}" >{L_DOWNLOADLOG_VIEW_LOG}</a><!-- ENDIF --></dd>
	</dl>
And save the file.
Open ext\dmzx\filedownload\styles\prosilver\template\event\attachment_file_prepend.html
This should result in this:
Grtz dmzx
uruguayito
Re: File Download & Downloadlog extenion combination
Post by uruguayito »
Oh no man :oops: :oops: :oops:
tky :buigen: dmzx
I'm a latin american man.
Spanish is my language.
merlinkv
    Windows 8.1 Firefox
Post by merlinkv »
Thanks dmzx, now my downloads looks great!! :thumbup:
tamarin
Post by tamarin »
Hello.
Why do I have all displayed double? (s. attachment)
tamarin
Post by tamarin »
tamarin wrote:Hello.
I found the problem!
I had installed an extension [Inline images in attachment].
I turned it off and the problem disappeared.
Thank you!
Mohammed AlSarsawi
Post by Mohammed AlSarsawi »
i use the steps to make the combination
but how to make downloadlog viewable to moderators not only admins
Thank you
I have both these exts into one ext and no edits needed.
	</dl>
	</dl>
:roll:
Painkiller88
    Mac OS X Firefox
Post by Painkiller88 »
ivailo95 wrote: Mar 2nd, '19, 08:10
	</dl>
	</dl>
:roll:
Can u explain a bit or do we have to figure out what it does and where to put?
I put it in \Downloadlog_v102\styles\prosilver\template\event attachment_file_prepend
i want to combine these two extension in one
Midway
Post by Midway »
With its code there is no longer the orange block it is replaced by the phpBB icon
before
then with his code
I know what is for this ext,just want it in one
Midway
Post by Midway »
You want the same of this ?
Midway wrote: Mar 2nd, '19, 09:57 you want the same of this ?
i want this
Midway
Post by Midway »
You have this here
Downloadlog
