BBCode DatabaseAll custom BBCodes in a dropdown box
BBCode's
    unknown unknown
Custom BBCodes in dropdown box.
Written by Simon
All custom BBCodes in a dropdown box.
Open styles/{YOURTHEMA}/template/posting_buttons.html
Find:
<!-- BEGIN custom_tags -->
          <input type="button" class="button2" name="addbbcode{custom_tags.BBCODE_ID}" value="{custom_tags.BBCODE_TAG}" onclick="bbstyle({custom_tags.BBCODE_ID})" title="{custom_tags.BBCODE_HELPLINE}" />
       <!-- END custom_tags -->
Replace by:
<select name="addbbcode_custom" onchange="bbstyle(this.form.addbbcode_custom.options[this.form.addbbcode_custom.selectedIndex].value*1);this.form.addbbcode_custom.selectedIndex = 0;">
          <option value="#" selected="selected">Custom BBCodes</option>
          <option value="{custom_tags.BBCODE_ID}" title="{custom_tags.BBCODE_HELPLINE}">{custom_tags.BBCODE_TAG}</option>
        </select>
Save, upload and refresh template.
iorG19
Re: Alle custom BBCodes in een dropdown box
Post by iorG19 »
Readers don't know what mean :
Zoek
Vervang door
Can you replace with english ? I don't speak netherlands :-)
:beers:
Niether do i but tell chrome to translate all pages :lol:
GEORGiOBBLOVER wrote:Readers don't know what mean :
Zoek
Vervang door
:beers:
Yes some translations have to be made on the forum. ;)
kaspir
Re: All custom BBCodes in a dropdown box
Post by kaspir »
Perfect, still works on 3.2 as I've noted here! :)
Just said goodbye to advanced bbcode box, this was the perfect alternative.
Check out phpBB contributions & extension downloads. :P
kaspir
Post by kaspir »
On second thought, I kept abbc3 and all its neat bbcodes, then just added this custom code to this file in /ext/vse/abbc3/styles/all/template to my liking if anyone wants likes, enjoy.
Now looks like this:
abbc3_posting_buttons.rar
:rolling: :rolling: try this
xiradorn_xbbcodesilkbtn_1_4_0.zip
cisco007
Post by cisco007 »
martin wrote: Jan 11th, '17, 12:31 :rolling: :rolling: try this
before i download this martin, what is the difference on the OP and this? you icons?
No edits to any files it's an ext also adds images as the fa fa icons look plain.
cisco007
Post by cisco007 »
Ok it's the same that i've had on my forum for years now, awesome! :tumbsyes: :tumbsyes:
You prob had the same as the rest of us edits :rolling: but np :tumbsyes:
I had this code in my site way before any of you did. :rolling:
kaspir
Post by kaspir »
martin wrote: Jan 12th, '17, 00:03 No edits to any files it's an ext also adds images as the fa fa icons look plain.
:buigen:
I learn as I go!
kaspir
Post by kaspir »
Getting a problem with MOD_X commands, they just show "MODX_FIND" or MODX_DELETE" as the helpline within post drop-down. They are not pretty like here. I do not see them in ACP, so can't edit there. They also don't parse, but then again neither is my username bbcodes either.
I might have a problem with most of my bbcodes, ever since the 3.2 update many of the helplines have vanished or defaulted to w/e the language variable is I guess. I'm pretty lost on this, any help would be appreciated as many of my bbcodes are broken and it probably has nothing to do with the extension you gave me martin. I'm also posting on phpbb I guess.
kaspir wrote: Jan 16th, '17, 08:36 I might have a problem with most of my bbcodes, ever since the 3.2 update many of the helplines have vanished or defaulted to w/e the language variable is I guess. I'm pretty lost on this, any help would be appreciated as many of my bbcodes are broken and it probably has nothing to do with the extension you gave me martin. I'm also posting on phpbb I guess.
To this problem the bbCodes are parsed different in 3.2 and you have to update them in your database. (otherwise they will not display correct)
