Off-TopicHow to fixed Birthday List On Top V3.3.8
All the various Off-Topic crap here ;)
HarveyWNvm LLC.
Post by HarveyWNvm LLC. »
I don't know why I get this error, can you do something, I will put all the codes
Error Stage:
phpBB encountered an error building the container due to an installed extension. For this reason, all extensions have been temporarily disabled. Please try purging your forum cache. All extensions will automatically be re-enabled once the container error is resolved. If this error continues, please visit phpBB.com for support.
Exception: The file "/home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/ext/hrvy/birthdaylistontop/config/services.yml" does not contain valid YAML: The reserved indicator "@" cannot start a plain scalar; you need to quote the scalar at line 5 (near "- @template").
#0 /home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/vendor/symfony/dependency-injection/Loader/YamlFileLoader.php(117): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->loadFile('/home/vol13_7/e...')
#1 /home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/phpbb/extension/di/extension_base.php(99): Symfony\Component\DependencyInjection\Loader\YamlFileLoader->load('services.yml')
#2 /home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/phpbb/extension/di/extension_base.php(63): phpbb\extension\di\extension_base->load_services(Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#3 /home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/vendor/symfony/dependency-injection/Compiler/MergeExtensionConfigurationPass.php(71): phpbb\extension\di\extension_base->load(Array, Object(Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationContainerBuilder))
#4 /home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/vendor/symfony/http-kernel/DependencyInjection/MergeExtensionConfigurationPass.php(39): Symfony\Component\DependencyInjection\Compiler\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#5 /home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/vendor/symfony/dependency-injection/Compiler/Compiler.php(140): Symfony\Component\HttpKernel\DependencyInjection\MergeExtensionConfigurationPass->process(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#6 /home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/vendor/symfony/dependency-injection/ContainerBuilder.php(789): Symfony\Component\DependencyInjection\Compiler\Compiler->compile(Object(Symfony\Component\DependencyInjection\ContainerBuilder))
#7 /home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/phpbb/di/container_builder.php(223): Symfony\Component\DependencyInjection\ContainerBuilder->compile()
#8 /home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/common.php(117): phpbb\di\container_builder->get_container()
#9 /home/vol13_7/epizy.com/epiz_32847785/htdocs/forum/adm/index.php(23): require('/home/vol13_7/e...')
#10 {main}
composer.json code:
   "name": "hrvy/birthdaylistontop",
   "type": "phpbb-extension",
   "description": "Moves the Birthday list to the head of the board",
   "homepage": "https://github.com/HarveyWNvm/nFL-CS.InFo/",
   "version": "V3.3.8",
   "time": "2023-06-11",
   "keywords": "Birthday",
   "license": "GPL-3.0",
   "authors": [{
         "name": "Stefan Salvatore",
         "username": "HarveyWNvm LLC.",
         "email": "harveynomvervevo@gmail.com",
         "role": "Extension Editor"
   "require": {
      "php": ">=7.4.8"
   "extra": {
      "display-name": "Birthday List On Top",
      "soft-require": {
           "phpbb/phpbb": ">=3.3.8,<4.0.*@dev"
      "version-check": {
         "host": "https://github.com/HarveyWNvm/nFL-CS.InFo/",
         "directory": "/versioncheck",
         "filename": "/blot__versions.json"
listener.php Code:
<?php
* @package Birthday List On Top Extension
* @copyright (c) 2023 HarveyWnvm
* @license https://opensource.org/license/gpl-3-0/ GNU General Public License version 3
namespace hrvy\birthdaylistontop\event;
* @ignore
use Symfony\Component\EventDispatcher\EventSubscriberInterface;
* Event listener
class listener implements EventSubscriberInterface
   /** @var \phpbb\template\twig\twig */
   protected $template;
   * Constructor for listener
   * @param \phpbb\config\config $config phpBB config
   * @param \phpbb\template\twig\twig $template phpBB template
   * @access public
   public function __construct(\phpbb\template\twig\twig $template)
      $this->template = $template;
   * Assign functions defined in this class to event listeners in the core
   * @return array
   * @static
   * @access public
   static public function getSubscribedEvents()
      return array(
         'core.page_header_after' => 'birthday_list',
   * Update the template variables
   * @param object $event The event object
   * @return null
   * @access public
   public function birthday_list($event)
         'S_DISPLAY_BIRTHDAY_LIST' => false,
Thanks for the start :buigen: :buigen:
nFL-Cs.InFo Clock to Banner
Re: How to fixed Birthday List On Top V3.3.8
What does the code look like in your config/services.yml :question:
In ext/hrvy/birthdaylistontop/config edit services.yml file
Find
           - @template
Replace by
           - '@template'
Clear the cache after modification
You can also use this extension: https://www.phpbb.com/customise/db/exte ... st_on_top/
phpBB: 3.3.15 | PHP: 8.5
HarveyWNvm LLC.
I will do it after I get home.
HarveyWNvm LLC.
Done and thank you! Lock Post
