Snippet Available Questions ⇒ Prefix CSS for Quick Title Edition 2.0.0
The Good
- Status: Offline
- User theme: Dark
Re: Prefix CSS for Quick Title Edition 2.0.0
Thanks my friend.. I will try it !
The Good
- Status: Offline
- User theme: Dark
I am just at the beginning I installed Quick Title Edition 2.0.0 ext\abdev\qte
but the ext is still not visible to Enable it !!
what I should to do ?
version phpbb 3.2.9
thanks
version phpbb 3.2.9
thanks
- Status: Offline
- User theme: Dark
Try to reinstall, sound weird but works.The Good wrote: Apr 22nd, '20, 18:32 I am just at the beginning I installed Quick Title Edition 2.0.0 ext\abdev\qte
but the ext is still not visible to Enable it !!![]()
version phpbb 3.2.9
thanks
The Good
- Status: Offline
- User theme: Dark
deleted and installed again but still the same.. maybe doesnt work 3.2.9 and PHP version: 7.1.33 !!!
- Status: Offline
- User theme: Dark
Must be working on 3.2.9.
You did look under "posting" tab in acp right?
The Good
- Status: Offline
- User theme: Dark
NO.. I checked Customise tab
- Status: Offline
- User theme: Dark
Install it and look under posting tab in acp for the settings.
The Good
- Status: Offline
- User theme: Dark
AH OK .. but where I should to go after !! Post settings ??
- Status: Offline
- User theme: Dark
Did you install it correct?
- Status: Offline
- User theme: Dark
Is there some confusion going on here with this ext ? https://www.phpbb.com/customise/db/exte ... cprefixes/ and dmzx version.
The Good
- Status: Offline
- User theme: Dark
folders are ext\ abdev \qte ( I have tried even qte-2.0.0-RC1 as folder )
you are in phpbb 3.2.9 ??
The Good
- Status: Offline
- User theme: Dark
martin wrote: Apr 22nd, '20, 20:33 Is there some confusion going on here with this ext ? https://www.phpbb.com/customise/db/exte ... cprefixes/ and dmzx version.
shoud I install this one too ??
- Status: Offline
- User theme: Dark
The Good wrote: Apr 22nd, '20, 20:35martin wrote: Apr 22nd, '20, 20:33 Is there some confusion going on here with this ext ? https://www.phpbb.com/customise/db/exte ... cprefixes/ and dmzx version.
No thats another prefix ext its just text with out colours.
The Good
- Status: Offline
- User theme: Dark
martin wrote: Apr 22nd, '20, 20:57The Good wrote: Apr 22nd, '20, 20:35martin wrote: Apr 22nd, '20, 20:33 Is there some confusion going on here with this ext ? https://www.phpbb.com/customise/db/exte ... cprefixes/ and dmzx version.
yeah I just installed it.. tried it !! worked fine but as you said just basic prefixes..
guys !! no one are in phpbb 3.2.9 + Quick Title Edition 2.0.0 ???
TWEagle
- Status: Offline
- User theme: Dark
Is it also possible to add before the QTE an image
I want the logo of the office product first and then the text.
Here under a little example
