3.1.x Extensions DatabaseHide Avatar for guests
Extension Name: Hide Avatar for guests
Hide avatar in viewtopic for guests as requested here viewtopic.php?p=2696#p2696
Added version check
none
  2. Unzip the downloaded release, and change the name of the folder to `hideavatar`.
  4. Copy the `hideavatar` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/hideavatar/composer.json
  6. Look for `Hide Avatar for guests` under the Disabled Extensions list, and click its `Enable` link.
This topic has 3 replies
