3.3.x Extensions DatabaseUser check
User check
Extension Name:
User check registration, checks if member already has an account registered so no double accounts will be allowed.
Can check if member use proxy to register doible account.
- Language update.
User check v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `usercheck`.
  4. Copy the `usercheck` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/usercheck/composer.json
  6. Look for `User check` under the Disabled Extensions list, and click its `Enable` link.
This topic has 19 replies
Register Logout
