Support Request SupportProblem to grab some images ( topic image )
Support Section
medic
Post by medic »
Your phpBB Version: 3.3.7
Boardlink: https://amis-med.com/forum
PHP Version: 7.4
The problem happen when there some special characters in the the topic title
Only way to fix is to remove ( ? ! : )
In this screen the image wasn't grabbed because of "?"
Thank you for all your good work 😊
Re: Problem to grab some images ( topic image )
Images dont tend to have special chars in there names they tend to be 1234.png or example.gif
medic
Post by medic »
Thanks for answer
Not sure why look this topic https://amis-med.com/forum/viewtopic.php?p=4073
Every time the topic title had "?" I get the same error
I use imgur but I think the grabbed image blocked because of "?" If I remove it from title and delete than grab again the image show up without problem 🤔
