Extension official releasesphpbb [3.2.x] Extensions Database Releases • User Notification Control
Extension name: User Notification Control
Author: Dark❶
Extension description: This Extension Lets Admin to control User Notification .
The phpBB's core & any other extension's notifications can be controlled (i.e. Enable/None/Disable) by this Extension.
Kindly note , this Extension does not allow to Create any New OR Delete any Notifications, it only displays & control's the existing Notifications.
Status Badge for User Notification Control [UNC] on phpBB v3.3.x :
Requirements: phpBB 3.2.8/3.3.x (or current 3.{3,2}.x dev) or above.
Features:
  • Option to Enable/Disable this extension.
  • Option to Enable / None / Disable for each User Notification for All Users.
    • Enable : To force Enable the Notification.
    • None : To let User select the Notification.
    • Disable : To force Disable the Notification.
  • Displays the Notification Controlled by Administrator in User's UCP Notification Options.
Links:
Instructions : Installation / Updation / Uninstallation
⚠️ No Language Key : Err0r "
No Language Key" for core or other extension(s)
GitHub Repository : usernotificationcontrol
GitHub Repository Language Packs : usernotificationcontrol> lang-pack
For more Details Go Here : User Notification Control [UNC]
EnJoY
Best Regards.
Extension version: 1.0.2
Download file: phpBB-ext-dark1-usernotificationcontrol-v1.0.2.zip
File size: 25.17 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?t=2587881&p=15690266#p15690266
