3.2 & 3.3 Extensions Databasephp info
php info
Extension Name: php info
Author: dmzx & martin
php information page can be set by permissions for groups if needed.
Not yet.
php info v1.0.0
  2. Unzip the downloaded release, and change the name of the folder to `phpinfo`.
  4. Copy the `phpinfo` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/phpinfo/composer.json
  6. Look for `php info` under the Disabled Extensions list, and click its `Enable` link.
This topic has 2 replies
