Question QuestionsWho Visited This Topic
Armis
Post by Armis »
I still have this error below:
Erreur générale
SQL ERROR [ mysqli ]
Expression #3 of SELECT list is not in GROUP BY clause and contains nonaggregated column 'wantete_wei20.w.counter_user' which is not functionally dependent on columns in GROUP BY clause; this is incompatible with sql_mode=only_full_group_by [1055]
SQL
SELECT w.user_id, w.topic_id, w.counter_user, w.date, u.username, u.user_colour, u.user_id, u.user_avatar, u.user_avatar_type, u.user_avatar_height, u.user_avatar_width, u.user_type, SUM(w.counter_user) AS total FROM phpbb_whovisitedthistopic w, phpbb_users u WHERE w.topic_id = 5 AND w.user_id = u.user_id GROUP BY w.user_id ORDER BY w.date DESC LIMIT 10
BACKTRACE
FILE: (not given by php)
LINE: (not given by php)
CALL: msg_handler()
LINE: 1023
CALL: trigger_error()
LINE: 195
FILE: [ROOT]/phpbb/db/driver/mysql_base.php
LINE: 45
LINE: 296
CALL: phpbb\db\driver\mysql_base->_sql_query_limit()
LINE: 337
CALL: phpbb\db\driver\driver->sql_query_limit()
FILE: [ROOT]/ext/dmzx/whovisitedthistopic/event/listener.php
LINE: 189
CALL: phpbb\db\driver\factory->sql_query_limit()
FILE: [ROOT]/vendor/symfony/event-dispatcher/EventDispatcher.php
LINE: 214
CALL: dmzx\whovisitedthistopic\event\listener->viewtopic_get_post_data()
LINE: 44
CALL: Symfony\Component\EventDispatcher\EventDispatcher->doDispatch()
FILE: [ROOT]/phpbb/event/dispatcher.php
LINE: 62
CALL: Symfony\Component\EventDispatcher\EventDispatcher->dispatch()
LINE: 46
CALL: phpbb\event\dispatcher->dispatch()
FILE: [ROOT]/viewtopic.php
LINE: 1321
CALL: phpbb\event\dispatcher->trigger_event()
The speed and reliability of your website in WANTETE WEB HOSTING :eusa_dance:
Your website and forum at 0.90 € /month without advertising or conditions. :ninja: :dance:
This topic has 11 replies
Register Logout
