3.2 & 3.3 Extensions Database 3.2 / 3.3Download limit
Download limit
Extension Name: Download limit
Download attachment limit. Can set in ACP the amount of downloads and hours and groups.
If counting in chrome or firefox give problems install this extension: Disable Cache
- Code cleanup.
- Code update for 3.3.x
- Code update for excluding groups when change to other group.
- Code update allowed extensions in ACP.
- Code update in listener.php for allowed extension.
- Code update for download count
- Code update in service.yml
- Code update in downloadlimit_prune.php
- Added allowed_extensions in listener.php
Download limit v1.0.5
  2. Unzip the downloaded release, and change the name of the folder to `downloadlimit`.
  4. Copy the `downloadlimit` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/downloadlimit/composer.json
  6. Look for `Download limit` under the Disabled Extensions list, and click its `Enable` link.
dani50
Re: Download limit
Post by dani50 »
Thanks a lot for extension, it works perfectly, for me it is very necessary is my forum.
Re: Download limit
dani50 wrote: 06 Jul 2019, 11:33 Thanks a lot for extension, it works perfectly, for me it is very necessary is my forum.
Np :wink:
Re: Download limit
THX will give it a try, I want to be able to set download amounts for certain groups.
Oh is this still counting image attachments as a download ?
Re: Download limit
Yes.
Re: Download limit
THX Martin :)
Re: Download limit
Re: Download limit
Was wondering if in some future release if there can be a counter for elapsed time so user know's how much longer they have to wait?
Thanks, very nice ext, been wanting it for several years :)
Re: Download limit
Re: Download limit
Acp image also updated :rolling:
Re: Download limit
martin wrote: 10 Jul 2019, 17:18 Acp image also updated :rolling:
Fast_Eddie
Re: Download limit
Post by Fast_Eddie »
In a future update could you add a members uploads under total downloads ?
:beers: Retirement 2024!
Re: Download limit
Fast_Eddie wrote: 22 Jul 2019, 22:54 925aba7bbb8ca9954510cd3b3b844564.png
Yes good idea!
Fast_Eddie
Re: Download limit
Thanks DM ! :)
Still keeping my fingers crossed for the '' upload ( or post ) now for more d/l's '' option :D
Re: Download limit
Just to be sure all uploads from that member including like jpg and zip for example?
