Various modifications for phpBB3Nice edit mchat function
Snippets for phpBB3
    unknown unknown
Nice edit mchat function.
This is for prosilver only.
Take the attached, unzip it and upload the file into your styles theme directory
apprise.zip
OPEN styles/xxx/theme/stylesheet.css
@import url("mchat.css");
@import url("apprise.css");
OPEN mchat_ajax_mini.js
var data=prompt(mChatEditInfo,message);if(data){
apprise(mChatEditInfo + ' (Shift and Enter for new line)',{'textarea':message,'animate':true,'position':200,'confirm':true}, function(r){if(r){
data:{mode:'edit',message_id:id,message:data}
data:{mode:'edit',message_id:id,message:r}
}},del
}})},del
if(confirm(mChatDelConfirm)){
apprise(mChatDelConfirm,{'position':200,'animate':true,'confirm':true},function(del){if(del){
}},refresh:
}else{return false;}});},refresh:
go to the end of mchat js file and paste this on a new blank line
    // Apprise 1.5 by Daniel Raftery
    // http://thrivingkings.com/apprise
    // Button text added by Adam Bezulski
    // Cached jQuery variables, position center added by Josiah Ruddell
    function apprise(a,b,c){a='<span style="font-weight:bold; font-size:1.2em;">'+a+"</span>";var d={confirm:false,verify:false,input:false,textarea:false,animate:false,textOk:"Ok",textCancel:"Cancel",textYes:"Yes",textNo:"No",position:"center"};if(b){for(var e in d){if(typeof b[e]=="undefined")b[e]=d[e]}}var f=$(document).height(),g=$(document).width(),h=$('<div class="appriseOuter"></div>'),i=$('<div class="appriseOverlay" id="aOverlay"></div>'),j=$('<div class="appriseInner"></div>'),k=$('<div class="aButtons"></div>'),l=300;i.css({height:f,width:g}).appendTo("body").fadeIn(100,function(){$(this).css("filter","alpha(opacity=70)")});h.prependTo("body");j.append(a).appendTo(h);if(b){if(b["input"]){if(typeof b["input"]=="string"){j.append('<div class="aInput"><input type="text" class="aTextbox" t="aTextbox" value="'+b["input"]+'" /></div>')}else{j.append('<div class="aInput"><input type="text" class="aTextbox" t="aTextbox" /></div>')}$(".aTextbox").focus()}if(typeof b["textarea"]=="string"){j.append('<div class="aInput"><textarea name="message" class="aEdit" style="height: 9em;" rows="5" cols="180">'+b["textarea"]+"</textarea></div>");$(".aEdit").focus()}}j.append(k);if(b){if(b["confirm"]||b["input"]){k.append('<button value="ok">'+b["textOk"]+"</button>");k.append('<button value="cancel">'+b["textCancel"]+"</button>")}else if(b["verify"]){k.append('<button value="ok">'+b["textYes"]+"</button>");k.append('<button value="cancel">'+b["textNo"]+"</button>")}else{k.append('<button value="ok">'+b["textOk"]+"</button>")}}else{k.append('<button value="ok">Ok</button>')}h.css("left",($(window).width()-$(".appriseOuter").width())/2+$(window).scrollLeft()+"px");if(b){if(b["position"]&&b["position"]==="center"){l=(f-h.height())/2}if(b["animate"]){var m=b["animate"];if(isNaN(m)){m=400}h.css("top","-200px").show().animate({top:l},m)}else{h.css("top",l).fadeIn(200)}}else{h.css("top",l).fadeIn(200)}$(document).keydown(function(a){if(i.is(":visible")){if(a.shiftKey&&a.keyCode==13){$(".aEdit").append("<br />")}else if(a.keyCode==13){$('.aButtons > button[value="ok"]').click()}else if(a.keyCode==27){$('.aButtons > button[value="cancel"]').click()}}});var n=$(".aTextbox").val();if(!n){n=false}$(".aTextbox").bind('keydown blur',function(){n=$(this).val()});var o=$(".aEdit").val();if(!o){o=false}$(".aEdit").bind('keydown blur',function(){o=$(this).val()});$(".aButtons > button").click(function(){i.remove();h.remove();if(c){$(this).text("");var a=$(this).attr("value");if(a=="ok"){if(b){if(b["input"]){c(n)}else if(b["textarea"]){c(o)}else{c(true)}}else{c(true)};$('#mChatMessage').focus();}else if(a=="cancel"){c(false);$('#mChatMessage').focus();}}})}
save the mchat js file, upload into the mchat directory on your forum, refresh the theme and your browsers cache.
Re: Nice edit mchat function
Was snooping around about mchat and this caught my eye.
But exactly what is it supposed to do and look like ?
clight77 wrote:Hi
Its already in 3.1.x version when you edit a message.
I am using v3.0.1.2
Is there a way to move the edit input box to the middle of the chat and not at the top above the overall_ header ?
Please and Thanks :)
EDIT:
Was an issue with SE_Gamer_Dark, got it fixed :)
Love it by the way.. Got the ccs done to suit my style.
Hi back again :)
One thing I am unable to figure out is how to change the background color of the edit input text area from #FFFFFF to another color and also change the font color #000000 to another color.
Cheers and thanks :)
Added an image:
Seems it has to do with javascript, I don't know enough about that to start editing in there.
I can live with it the way it is :)
OK :)
Thought I would post back on how I changed the text size and background color of the edit input box for mchat v 1.3.8, and it does not seem to interfere with my SE_Gamer_Dark (modified) style functions that I can tell. (prosilver based) phpbb 3.0.1.2
Open: styles/themes/forms.css
Find:
textarea {
	width: 60%;
	padding: 2px;
	font-size: 0.8em;
	line-height: 1.4em;
	font-family: Arial, Helvetica, sans-serif;
Replace with:
textarea {
   background-color: #262626;  /*select your template background color here*/
   color: #ffffff; /*select your text color here*/
	width: 60%;
	padding: 2px;
	font-size: 1em;  /*select your text/font size here*/
	line-height: 1.4em;
That's it :)
Or you could just edit mchat.css file with the right edits :whistl:
martin wrote:or you could just edit mchat.css file with the right edits :whistl:
Tried that it did not work I am afraid, at least not for me :(
But then again if you mean add lines to it, I am not tha good at coding..
What would you suggest in mchat.css ?
Did you create a directory theme/SE_Gamer_Dark/ for this style?
You should be adjusting edits in there or it will effect other styles.
Do this in mchat's theme/ directory also.
Mchat 0.1.4 has this built in now.
Sniper_E wrote:Did you create a directory theme/SE_Gamer_Dark/ for this style?
I only use the SE_GAMER_DARK style and do all modifications to it only.
martin wrote:mchat 0.1.4 has this built in now.
Thanks but I am not changing to phpbb 3.1.
I have way to many modifications over the years and I do not wish to redo them all :(
You dont need to i had a bucket full of mods and edits and im on 3.1.6 you just need to make the jump :tumbsyes:
