GeneralA problem with Cynthia
General information
oronzocanà
Post by oronzocanà »
Hi.
I must install the Cynthia styles for 3.2.0 (it's an upgrade)
But its a long time (over 1 year) that I don't update this forum and I forgot quite everything.
I hope you can help me to install the style and configure it correctly or, in case, tell me where I can find a good tut...
:wave:
Re: A problem with Cynthia
By the looks of the images you posted (then deleted) the style was for 3.1 not 3.2
oronzocanà
martin wrote: Mar 10th, '17, 00:12 By the looks of the images you posted (then deleted) the style was for 3.1 not 3.2
Correct.
Now, the right version is up
but I'm facing some probs:
a. Eliminate that "Cynthia" at point 1
b. Set section 2 color as in section 3
c. Set section 4 color as in section 5
Thanks.
Bruns
There's one more thing, probably. But I'll wait...
oronzocanà
oronzocanà wrote: Mar 10th, '17, 16:13
Correct.
Thanks.
Bruns
tsk tsk....
oronzocanà
I promise i wont be rude again for a theme i should NOT be using on phpbb 3.2.
Edited my martin
oronzocanà wrote: Mar 15th, '17, 16:26 Forum assurdo, nemmeno su phpbb.com sono così lassisti e menesbattisti...
Great answer. Don't think you will get any support now.
Ask help @ the style author ...
Post locked some ppl have real lives and are not on hand to fix 3.1 styles to 3.2
