3.2 & 3.3 Extensions DatabaseFile Upload
File Upload
Extension Name: File Upload
Author: dmzx & martin
This extension will add an upload system for files to your forum.
This will allow you to host your own files from your server rather than use a 3rd party.
Allowed extensions 'zip', 'rar'
Set permission for groups, default only admin group can upload files.
- Rename "files" dir to "file-files"
- Code update for 3.3.x
- Changed code for ACP for deleting images.
- Change column filesize to BINT
- Dropped support of 3.1.x
- Added folder.
Added copy button by martin.
Twig update.
Update URL in files and copyright.
Code Update.
File Upload v1.0.5
  2. Unzip the downloaded release, and change the name of the folder to `fileupload`.
  4. Copy the `fileupload` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/fileupload/composer.json
  6. Look for `File Upload` under the Disabled Extensions list, and click its `Enable` link.
This topic has 142 replies
