Various modifications for phpBB3Mchat top poster
Snippets for phpBB3
Mchat top poster
Mchat top poster
this will show a users Mchat post count (Not forum post count)
Open mchat.php
// Run code...
            if ($mchat_view)
$sql = 'SELECT m.user_id, COUNT(m.message_id) AS post_count, u.username, u.user_colour
                    FROM ' . MCHAT_TABLE . ' m
                        LEFT JOIN ' . USERS_TABLE . ' u ON (m.user_id = u.user_id)
                        GROUP BY u.user_id ORDER BY post_count DESC';
                $result = $db->sql_query_limit($sql, 10);
                while ($row = $db->sql_fetchrow($result))
                    $template->assign_block_vars('mchaters', array(
                        'USER_NAME'        => get_username_string('no_profile', $row['user_id'], $row['username'], $row['user_colour']) . ' (' . $row['post_count'] . ')',
                $db->sql_freeresult($result);
Open language/en/mods/mchat_lang.php
'MCHAT_SMILES'                => 'Smilies',
'MCHAT_TOP_POSTERS'            => 'Top Posters',
Open styles/your style/template/mchat_body.html
<div style="text-align:center;">{L_MCHAT_COPYRIGHT}</div>
<!-- IF .mchaters --><p><strong>{L_MCHAT_TOP_POSTERS}</strong><br/>
             <!-- BEGIN mchaters -->{mchaters.USER_NAME} <!-- IF not mchaters.S_LAST_ROW -->,<!-- ENDIF --><!-- END mchaters --></p><!-- ENDIF -->
Napster
Re: Mchat top poster
Post by Napster »
Hi, would love this but these edits are different on the new mchat extension is it possible to show me where new edits go please.
The edits in the extension are close to the same.
Instead of editing the mchat.php you will edit the core/render_helper.php.
dmzx wrote:
Open core/render_helper.php
Find This may be a partial find and not the whole line [ line 1080 ]
				// Run code...
				if ($mchat_view)
                    FROM ' . $this->mchat_table . ' m
                $result = $this->db->sql_query_limit($sql, 10);
                while ($row = $this->db->sql_fetchrow($result))
                    $this->template->assign_block_vars('mchaters', array(
                $this->db->sql_freeresult($result);
And the edit to the mchat_body.html has a different Find.
dmzx wrote:
Open styles/prosilver/template/mchat_body.html
				{L_MCHAT_COPYRIGHT}
The language file edit is the same.
dmzx wrote:
Open language/en/common.php
	//Custom edits
	'REPLY_WITH_LIKE'	=>'Like This Post',
Napster
Post by Napster »
Thank you :buigen:
alfi0815
Post by alfi0815 »
and for mchat 1.0.0 RC1???
alfi0815 wrote: Feb 16th, '16, 18:26 Hello,
There is in this section
killfrenzy
Post by killfrenzy »
Sniper_E wrote: Dec 20th, '15, 19:54 The edits in the extension are close to the same.
				// Run code...
				if ($mchat_view)
				{L_MCHAT_COPYRIGHT}
	//Custom edits
What version of mchat is this? I can't find render_helper.php in core folder. I'm using mchat 3.4
Androidcribs.com
Androidcribs
killfrenzy wrote: Feb 17th, '16, 03:44 Instead of editing the mchat.php you will edit the core/render_helper.php.
The latest version dont use render_helper no more.
There is now an extension for this (addon) to add the Top Poster, no need to edit anything no more.
killfrenzy
dmzx wrote: Feb 17th, '16, 20:05
This is for donators only latest version of mchat?
There is an extension in VIP indeed.
sindyciaray
Post by sindyciaray »
Seems like the real post here cheers I PROMISE I WONT POST BS LINKS TO FAT SITES NO MORE
edited by martin
sindyciaray wrote: Sep 15th, '17, 11:22 Seems like the real post here cheers I PROMISE I WONT POST BS LINKS TO FAT SITES NO MORE
edited by martin
:thumbup: Martin :lol:
