3.2.x Extensions DatabaseForm Maker/Creator 3.2.x
Magic user status: Online
Extension Name: Form Maker/Creator
Author: dmzx - michaelo
Create forms to collect data from you members in any forum (one form per forum)
Note: still some code to check so dev.
Update template with Twig
Changed code for php 7.x
Code update.
Form Maker Creator v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `formcreator`.
  4. Copy the `formcreator` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/formcreator/composer.json
  6. Look for `Form Maker/Creator` under the Disabled Extensions list, and click its `Enable` link.
This topic has 115 replies
Register Logout
