3.2.x Extensions Database 3.2 / 3.3Form Maker/Creator 3.2.x
Extension Name: Form Maker/Creator
Author: dmzx - michaelo
Create forms to collect data from you members in any forum (one form per forum)
Note: still some code to check so dev.
dmzx/Form-Maker-Creator
Update template with Twig
Changed code for php 7.x
Code update.
Form Maker Creator v1.0.1
  2. Unzip the downloaded release, and change the name of the folder to `formcreator`.
  4. Copy the `formcreator` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/formcreator/composer.json
  6. Look for `Form Maker/Creator` under the Disabled Extensions list, and click its `Enable` link.
zardos
Re: Form Maker/Creator 3.2.x
Post by zardos »
Thanks dm, great ext. :wink:
infspirit
Post by infspirit »
Spanish translation ;)
Hippie459MN
Post by Hippie459MN »
Very nice! Is there anyway to make the new post default to the form so one wouldnt have to click the button?
Would be awesome if this worked on 3.1.x also cause im not ready to update. 75% of my installed extensions dont work with 3.2.0 :(
"I went outside once. The graphics sucked but the game play was ok."
Hippie459MN wrote: 11 Jan 2017, 01:04 Very nice! Is there anyway to make the new post default to the form so one wouldnt have to click the button?
Need to check on 3.1 opoesiemen also requested it, but need to check if it is possible.
mh254
Post by mh254 »
Very nice. Would be great if it is possible to force the form mode for the first post of a topic.
German language files [DE]
Joost
Post by Joost »
Is there a Dutch translation ?
Warning using this ext will remove any custom buttons you have added if any.
Hippie459MN
martin wrote: 11 Feb 2017, 17:38 Warning using this ext will remove any custom buttons you have added if any.
What do you mean? What kind of custom buttons?
It will hide the default submit button field.
Joost
Post by Joost »
I see this error..
Fatal error: Redefinition of parameter $form_id in /home/vhosts/hpmagicworld.nl/httpdocs/ext/dmzx/formcreator/controller/admin_controller.php on line 332
Honcho
Post by Honcho »
I previously had this on 3.1.7 and recently updated to 3.2 and also updated to the newest version of Form Maker and no longer see the "form" button in the posting a topic area. Any help would be appreciated.
It still shows my current version as 1.0.0-dev.
Honcho wrote: 21 Feb 2017, 20:10 I previously had this on 3.1.7 and recently updated to 3.2 and also updated to the newest version of Form Maker and no longer see the "form" button in the posting a topic area. Any help would be appreciated.
Did you add a form and select a forum in ACP?
Honcho
Post by Honcho »
dmzx wrote: 21 Feb 2017, 22:05
Yes sir. I even deleted the entire thing and reinstalled it. It's weird because if I go to that forum and create a new topic, the button isn't there but, if I just hit preview without entering anything it will show up with the code. It also shows _ between each word.
