Question Questions ⇒ Update to 3.1.10
ArrayKinsman
- Status: Offline
- User theme: Dark
Update to 3.1.10
So with 80 extensions and a few core mods I'm dubious about updating from 3.1.9, anybody else had any issues?
ArraySniper_E
- Status: Offline
- User theme: Dark
Re: Update to 3.1.10
I don't have 80 extensions but I'll try the update right now and see how smooth it is.
I'm sure your core mods will need to be done again manually.
Here I go!
Here I go!
ArraySniper_E
- Status: Offline
- User theme: Dark
OK the update went real smooth.
See if people on .com are having problems first. My small site is not a real test.
- I backed up my database first. (Didn't need to though)
- Uploaded files from the phpBB-3.1.9_to_3.1.10 download.
- Navigated to the install/ directory and started the update.
- After comparing the files I downloaded the changed files.
- Uploaded the changed files and compared the files again.
- I had to ftp manually delete the language/en/search_ignore_words.php and search_synonyms.php files.
- Compared files again and was able to continue the update.
- Updated the database and was finished.
Arraydavidmccl2
- Status: Offline
- User theme: Dark
Update went smooth had a small problem with the launguage/En had to remove the files they listed guess they were extras haha
ArrayTarantino
- Status: Offline
- User theme: Dark
I had problems on updating. Because of the migrator files... Phpbb devs have done a bad decision and broked even validated extensions... :/
But they say it will only broke bad coded extensions... But those were validated... Strange isn't it?
[ Post made via Android ]
ArrayKinsman
- Status: Offline
- User theme: Dark
Did mine last night, only 3 modified files, it all seems ok so far.
Arrayfaroud
- Status: Offline
- User theme: Dark
In custom profile fields in your acp
there is a bug that you can solve with this fix
https://github.com/phpbb/phpbb/pull/448 ... 4fbff34c69
You get an error when adding or removing anything
the update 3.1.10
the update 3.1.10
