BBCode DatabaseGoogle Font BBcode
BBCode's
Fast_Eddie
Google Font BBcode
Post by Fast_Eddie »
I have a working BBcode to use google fonts
BBcode:
[googlefont={TEXT}]{TEXT2}[/googlefont]
HTML Replacement:
  WebFontConfig = {
    google: { families: [ '{TEXT}::latin' ] }
  (function() {
    var wf = document.createElement('script');
    wf.src = ('https:' == document.location.protocol ? 'https' : 'http') +
      '://ajax.googleapis.com/ajax/libs/webfont/1/webfont.js';
    wf.type = 'text/javascript';
    wf.async = 'true';
    var s = document.getElementsByTagName('script')[0];
    s.parentNode.insertBefore(wf, s);
  })();</script><span style="font-family:{TEXT};">{TEXT2}</span>
Help Line:
[googlefont=fontname][your text here][/googlefont]
Problem is when i submit I get this warning:
The BBCode you are trying to add seems to use a {TEXT} token inside a HTML attribute. This is a possible XSS security issue. Try using the more restrictive {SIMPLETEXT} or {INTTEXT} types instead. Only proceed if you understand the risks involved and you consider the use of {TEXT} absolutely unavoidable.
Can this be updated? How?
Thank you in advance! :buigen:
Re: Google Font BBcode
Try this:
BBCode usage
[googlefont={INTTEXT}]{INTTEXT2}[/googlefont]
HTML replacement
  WebFontConfig = {
    google: { families: [ '{INTTEXT}::latin' ] }
  (function() {
    wf.async = 'true';
  })();</script><span style="font-family:{INTTEXT};">{INTTEXT2}</span>
Help line
Fast_Eddie
Thanks 'D' You 'da man! That did the trick :tumbsyes:
