3.2.x Extensions Database 3.2 / 3.3Link menu 3.2.x
Link menu 3.2.x
Extension Name: Link menu 3.2.x
This extension will add a simple link menu to header and place the search box in navbar.
  2. Unzip the downloaded release, and change the name of the folder to `linkmenu`.
  4. Copy the `linkmenu` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
    (your forum root)/ext/dmzx/linkmenu/composer.json
  6. Look for `Link menu` under the Disabled Extensions list, and click its `Enable` link.
Re: Link menu 3.2.x
dmzx and martin Thanx U :tumbsyes:
Link_menu_3_2_x - Dutch translation.zip
awr
    Mac OS X Safari
Re: Link menu 3.2.x
Post by awr »
Turkish Language Pack
tr.zip
Re: Link menu 3.2.x
German language file [DE]
bcurran3
Re: Link menu 3.2.x
Post by bcurran3 »
FEATURE REQUEST: Change to drop down menu (on navbar) with possibility of "infinite" links. :beers:
AndrewP
Re: Link menu 3.2.x
Post by AndrewP »
FEATURE REQUEST: Can it be set that the linked site opens in a new tab (or new window) rather than in place of my forum?
AndrewP
Funny
Re: Link menu 3.2.x
Post by Funny »
Use External Links Open in New Window Extension.
:eyes2:
Webmaster Chuck
Re: Link menu 3.2.x
Post by Webmaster Chuck »
Funny wrote: 23 Mar 2017, 23:09 Hi
:eyes2:
I'm using that extension, and it does not open in an external window. Suggestions?
Webmaster Chuck
Re: Link menu 3.2.x
Worked like a champ, with the exception of:
<div class="menu-block" style="float: {S_CONTENT_FLOW_END}; width: 8%;">
needed to be put back to the original line:
<div class="menu-block" style="float: {S_CONTENT_FLOW_END}; width: 19%;">
Otherwise, it made the line break off to 2 lines, instead of 1.
Thank you for the quick response.
Re: Link menu 3.2.x
Yup as the post was for 3.1 :thumbup:
luca17000
Re: Link menu 3.2.x
Post by luca17000 »
Good evening, I would like to know if it is possible to add several links or one is limited to three..
Re: Link menu 3.2.x
luca17000 wrote: 12 May 2018, 18:38 Good evening, I would like to know if it is possible to add several links or one is limited to three..
Limited to 3 for now.
luca17000
Re: Link menu 3.2.x
Post by luca17000 »
Tks
Re: Link menu 3.2.x
