Special thanks to: martin & Sniper_E
Extra navbar select menu use dmzx_navbar_quick_links as event to add the links.
Change language file to whatever you want the call the navbar menu.
See "Games" menu in navbar here.
- Download-link
- Navbar 3.2.x v1.0.0
- Unzip the downloaded release, and change the name of the folder to `navbar`.
- Copy the `navbar` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at
(your forum root)/ext/dmzx/navbar/composer.json - Navigate in the ACP to `Customise -> Manage extensions`
- Look for `Navbar` under the Disabled Extensions list, and click its `Enable` link.
