3.2 & 3.3 Extensions DatabaseKnuffel
Knuffel
Extension Name: Knuffel
With this extension you can add a Knuffel game to your forum Knuffel (Kniffel-Clone, also known as Yahtzee or dicepoker) is a dice game, where it's your aim to roll certain figures and reach a maximum score out of them.
- updated code for php 8.x
- Update code for 3.3.x.
- Twig update.
- Drop support for 3.1.
Made code compatible for 3.2
Code update
Added correct url
Knuffel v1.0.4
  2. Unzip the downloaded release, and change the name of the folder to `knuffel`.
  4. Copy the `knuffel` folder to `/ext/dmzx/` if done correctly, you'll have the main extension class at (your forum root)/ext/dmzx/knuffel/composer.json
  6. Look for `Knuffel` under the Disabled Extensions list, and click its `Enable` link.
This topic has 46 replies
Register Logout
