boldherri
Posts: 46 Joined: 31 May 2018, 15:28
Post
by boldherri » 01 Jun 2018, 18:13
Sniper_E wrote: 01 Jun 2018, 18:03
boldherri wrote: 31 May 2018, 22:52
I'm sorry that nobody here in the forum gave me a simple advice
You just posted this yesterday afternoon. And I am just now seeing your post here this morning.
No one is sitting online here waiting for your post to come in so they can give you an immediate response.
It's like you expected an instant response. There is no Live Help available on these sites waiting to help you.
Please go cry somewhere else about that. And no one is bound to give help that fast so please don't demand it.
ok but it took 2 seconds to respond, i never claimed help,
I had to write on another forum to help me and i immediately resolved.
ok I'm crying :(
lopoto
Posts: 74 Joined: 28 Dec 2014, 01:59
Post
by lopoto » 05 Aug 2018, 19:49
How to add, ACP and MCP? for tools, tabs
Posts: 919 Joined: 02 Feb 2018, 12:04
Post
by ivailo95 » 07 Aug 2018, 20:46
to me it's games how can i rename it and add ACP and MCP and other things?
lopoto
Post
by lopoto » 10 Aug 2018, 01:05
In ext no problems , only ACP and MCP is magic
lopoto
Post
by lopoto » 12 Aug 2018, 22:13
lopoto wrote: 05 Aug 2018, 19:49
Posts: 1160 Joined: 14 Oct 2014, 19:01
Post
by Sniper_E » 13 Aug 2018, 01:12
Open: navbar/styles/prosilver/template/event/overall_header_navigation_prepend.html
<!-- IF not S_IS_BOT and S_USER_LOGGED_IN -->
<li id="quick-links" class="quick-links responsive-menu dropdown-container<!-- IF not S_DISPLAY_QUICK_LINKS and not S_DISPLAY_SEARCH --> hidden<!-- ENDIF -->" data-skip-responsive="true">
<a href="#" class="responsive-menu-link dropdown-trigger">
<i class="icon fa-bars fa-fw" aria-hidden="true"></i><span>{L_NAVBAR_LINKS}</span>
</a>
<div class="dropdown hidden">
<div class="pointer"><div class="pointer-inner"></div></div>
<ul class="dropdown-contents-navbar" role="menu">
<!-- EVENT dmzx_navbar_quick_links -->
</ul>
</div>
</li>
<!-- IF U_ACP or U_MCP -->
<li id="quick-mod-links" class="quick-links responsive-menu dropdown-container<!-- IF not S_DISPLAY_QUICK_LINKS and not S_DISPLAY_SEARCH --> hidden<!-- ENDIF -->" data-skip-responsive="true">
<i class="icon fa-gavelfa-fw" aria-hidden="true"></i><span>{L_MOD_TOOLS}</span>
</a>
<!-- IF U_ACP -->
<li data-last-responsive="true">
<a href="{U_ACP}" title="{L_ACP}" role="menuitem">
<i class="icon fa-cogs fa-fw" aria-hidden="true"></i><span>{L_ACP_SHORT}</span>
</a>
</li>
<!-- IF U_MCP -->
<a href="{U_MCP}" title="{L_MCP}" role="menuitem">
<i class="icon fa-gavel fa-fw" aria-hidden="true"></i><span>{L_MCP_SHORT}</span>
</a>
</li>
</ul>
</div>
</li>
Open: navbar/language/en/common.php
'NAVBAR_LINKS' => 'Games',
'MOD_TOOLS' => 'Tools',
Try that...
Posts: 5117 Joined: 06 Apr 2014, 16:12
Post
by martin » 13 Aug 2018, 01:46
New cssmagic can deal with this ext but its not released yet
I did not add lang as was just testing
Post
by ivailo95 » 13 Aug 2018, 19:31
Navbar_3_2_x\navbar\styles\prosilver\template\event
</a>
</ul>
</div>
</li>
</a>
<!-- IF U_ACP -->
</a>
</li>
<!-- IF U_MCP -->
</a>
</li>
</ul>
</div>
</li>
Navbar_3_2_x\navbar\language\en
<?php
* @package phpBB Extension - Navbar
* @copyright (c) 2016 dmzx - http://www.dmzx-web.net
* DO NOT CHANGE
if (!defined('IN_PHPBB'))
exit;
if (empty($lang) || !is_array($lang))
$lang = array();
// DEVELOPERS PLEASE NOTE
// All language files should use UTF-8 as their encoding and the files must not contain a BOM.
// Placeholders can now contain order information, e.g. instead of
// 'Page %s of %s' you can (and should) write 'Page %1$s of %2$s', this allows
// translators to re-order the output of data while ensuring it remains correct
// You do not need this where single placeholders are used, e.g. 'Message %d' is fine
// equally where a string contains only two placeholders which are used to wrap text
// in a url you again do not need to specify an order e.g., 'Click %sHERE%s' is fine
// Some characters you may want to copy&paste:
I clear the cache and press CTR+R and F5
i saw it broke my board
Post
by martin » 13 Aug 2018, 19:35
Post
by ivailo95 » 13 Aug 2018, 19:36
What? o.o
Post
by martin » 13 Aug 2018, 19:37
If you ask me you should leave it alone get some one who will do it some will do it for free some will charge i think after reading your posts you should get a guy to do your stuff.
Voice4Vision
Posts: 19 Joined: 16 Dec 2017, 05:34
Post
by Voice4Vision » 15 Aug 2018, 21:56
Sniper_E wrote: 13 Aug 2018, 01:12
</a>
</ul>
</div>
</li>
</a>
<!-- IF U_ACP -->
</a>
</li>
<!-- IF U_MCP -->
</a>
</li>
</ul>
</div>
</li>
Try that...
I managed to get this working Ed, but a couple of additional questions relating to this.
How do I remove the original ACP and MCP links?
How may I add the stk link?
And last question...
How would I create the navbar links for FAQ and BBcode FAQ?
Post
by Sniper_E » 16 Aug 2018, 06:48
Voice4Vision wrote: 15 Aug 2018, 21:56
The original/duplicate acp and mcp links are in your style's template/navbar_header.html template.
<!-- IF U_ACP -->
</a>
</li>
<!-- IF U_MCP -->
</a>
</li>
Either remove those lines or comment them out.
You can add the stk links by installing this ext.
stklinks_1.0.1.zip
I will have to create the navbar links for FAQ and BBcode FAQ and share with you later.
Voice4Vision
Post
by Voice4Vision » 16 Aug 2018, 08:38
Sniper_E wrote: 16 Aug 2018, 06:48
<!-- IF U_ACP -->
</a>
</li>
<!-- IF U_MCP -->
</a>
</li>
stklinks_1.0.1.zip
I got it...everything. To inlcude my FAQ and BBCode
The BBcode was a bit of a challenge, since it was never fully implemented into phpBB 3.2
My file are as follows.
ext/dmzx/navbar/styles/prosilver/template/event/overall_header_navigation_prepend.html
</a>
</ul>
</div>
</li>
<li id="extensions-links" class="quick-links responsive-menu dropdown-container" data-skip-responsive="true">
<i class="icon fa-bars fa-fw" aria-hidden="true"></i><span>{{ lang('Extensions') }}</span>
</a>
<ul class="dropdown-contents" role="menu">
<!-- EVENT dmzx_navbar_extensions -->
</ul>
</div>
</li>
<li id="help-links" class="quick-links responsive-menu dropdown-container" data-skip-responsive="true">
<i class="icon fa-bars fa-fw" aria-hidden="true"></i><span>{{ lang('Help') }}</span>
</a>
<li <!-- IF not S_USER_LOGGED_IN -->data-skip-responsive="true"<!-- ELSE -->data-last-responsive="true"<!-- ENDIF -->>
<a href="{U_FAQ}" rel="help" title="{L_FAQ_EXPLAIN}" role="menuitem">
<i class="icon fa-question-circle fa-fw" aria-hidden="true"></i><span>{L_FAQ}</span>
<a href="/help/bbcode" rel="help" title="{L_BBCODE_EXPLAIN}" role="menuitem">
<i class="icon fa-code fa-fw" aria-hidden="true"></i><span>{L_BBCODE_GUIDE}</span>
</ul>
</div>
</li>
<li id="admin-links" class="quick-links responsive-menu dropdown-container<!-- IF not S_DISPLAY_QUICK_LINKS and not S_DISPLAY_SEARCH --> hidden<!-- ENDIF -->" data-skip-responsive="true">
<i class="icon fa-gavel fa-fw" aria-hidden="true"></i><span>{{ lang('Admin') }}</span>
</a>
<!-- IF U_ACP -->
</a>
</li>
<!-- IF U_MCP -->
</a>
</li>
{% if U_ACP %}
<a href="./stk" title="{{ lang('STK') }}" role="menuitem">
<i class="icon fa-wrench fa-fw" aria-hidden="true"></i><span>{{ lang('STK_SHORT') }}</span>
</a>
</li>
{% endif %}
</ul>
</div>
</li>
Thank you Ed. You are helping move on to bigger things today!!!
Post
by martin » 16 Aug 2018, 09:53
I may sort mine out and post it its all in one ext but i have removed the acp and mcp from core.
