Your phpBB Version: 3.1.6
Your knowledge: Beginner
Boardlink: http://www.fishnbc.com/phpbb
Loaded link menu 1.0.0 from phpbb extention directory, enabled it under customize and entered the link names and URLs under extentions. The links show up fine in the header, but don't work when clicked.
Tried dis-ableing and re-enabling, long and short urls and disabling some other extentions. Using Pro-Silver.
Support Request Support ⇒ Link Menu not working
ArrayChrisS
- Status: Offline
- User theme: Dark
Arraydmzx
- Status: Offline
- User theme: Dark
Re: Link Menu not working
Switch off the lights, it looks like that is causing the problem.
ArrayChrisS
- Status: Offline
- User theme: Dark
Thanks, switching off the lights did the trick.
