Solved QuestionsDownload ext
moffacostanzo
Download ext
Post by moffacostanzo »
when i enter in the category download
i receive this message
[phpBB Debug] PHP Notice: in file [ROOT]/includes/message_parser.php on line 1198: Undefined index: TOO_FEW_CHARS
Re: Download ext
moffacostanzo wrote: Mar 4th, '17, 10:29 hi
Are you using latest version?
moffacostanzo
    Mac OS X Firefox
Re: Download ext
Yes
Re: Download ext
Can you try to add a description to the file?
moffacostanzo
    Mac OS X Firefox
Re: Download ext
This is my file
message_parser.php.zip
moffacostanzo
Re: Download ext
I don't understand
moffacostanzo
Re: Download ext
i try to disable all ext but nothing i have the same problem
Re: Download ext
moffacostanzo wrote: Mar 6th, '17, 11:56 hi
Install the download extension and fill all fields like this:
And see if error is gone.
Re: Download ext
Posted on mine too you need to fill out the form.
if (!$message_length || $message_length < (int) $config['min_post_chars'])
				$this->warn_msg[] = (!$message_length) ? $user->lang['TOO_FEW_CHARS'] : ($user->lang('CHARS_POST_CONTAINS', $message_length) . '<br />' . $user->lang('TOO_FEW_CHARS_LIMIT', (int) $config['min_post_chars']));
				return (!$update_this_message) ? $return_message : $this->warn_msg;
Re: Download ext
martin wrote: Mar 6th, '17, 17:12 Posted on mine too you need to fill out the form.
:lol: Yes I see now..
Re: Download ext
I posted this in your topic on mine but might aswell share with others as all users will get the error message.
You could also set the min chars allowed in ACP/posting/post setting.
The ext takes phpbbs post setings so you can change them to fix it.
