Various modifications for phpBB3 ⇒ Forum Link to Topic Title
- Status: Offline
- User theme: Dark
Re: Forum Link to Topic Title
Just uninstalled this and trying that ext you pointed out.
- Status: Offline
- User theme: Dark
- Status: Offline
- User theme: Dark
What exactly needs to be replaced in the newest 3.2 version to get this to work properly? All items in this post have been edited as it states, except the $relative_url; - it does not exist in the newest functions_content file. I guess I should ask is this code change still valid for the 3.2 board?
Open: includes/functions_content.php
$text = $relative_url;
$text = fetch_forumtitle($url);
$text = htmlspecialchars($text);
$text = str_replace('&', '&', $text);
* make_clickable function
Add before Add these lines on a new blank line before the preceding line(s) to find
* BartVB Show actual forumname or topic title instead of link to forum URLs
function fetch_forumtitle($url)
global $db, $auth;
// Search for relevant URL parameters (preceded by '?' or 'amp;'
if(preg_match_all('/(?:\?|&)([ptf])=(\d+)/', $url, $matches))
$post_id = $topic_id = $forum_id = 0;
foreach($matches[1] as $set => $param)
switch ($param)
case 'p':
$post_id = $matches[2][$set];
break;
case 't':
$topic_id = $matches[2][$set];
break;
case 'f':
$forum_id = $matches[2][$set];
break;
if ($forum_id != 0 && !$auth->acl_get('f_read', $forum_id))
return $url;
if ($topic_id != 0 || $post_id != 0)
$sql = "SELECT
t.forum_id, topic_title, forum_name " . ($post_id != 0 ? ", username" : "") . "
FROM " .
($post_id != 0 ? POSTS_TABLE . " p, " . USERS_TABLE . " u, " : "") .
TOPICS_TABLE . " t
LEFT JOIN " . FORUMS_TABLE . " f ON (t.forum_id = f.forum_id)
WHERE " .
($post_id != 0 ? "post_id = $post_id AND p.topic_id = t.topic_id AND p.poster_id = u.user_id " : "topic_id = " . $topic_id);
$result = $db->sql_query($sql);
if($row = $db->sql_fetchrow($result))
if (!$auth->acl_get('f_read', $row['forum_id']))
return $url;
$username = ($post_id != 0) ? $row['username'] . " @ " : '';
$forum_abbr = (preg_match('/^(\[.+\])/', $row['forum_name'], $matches)) ? $matches[1] . ' ' : '';
return $username . $forum_abbr . $row['topic_title'];
elseif ($forum_id != 0)
$sql = "SELECT forum_name FROM " . FORUMS_TABLE . " WHERE forum_id = " . $forum_id;
if ($row = $db->sql_fetchrow($result))
return $row['forum_name'];
return $url;
- Status: Offline
- User theme: Dark
No longer works on 3.2 there is other ext's out now that do the same but work.
- Status: Offline
- User theme: Dark
Yeah, found out the hard way... Any pointers as to an extension that will do something similar?
- Status: Offline
- User theme: Dark
Where? Have you a link?martin wrote: Feb 19th, '17, 20:56 No longer works on 3.2 there is other ext's out now that do the same but work.
