Extension official releasesphpbb [3.3.x] Extensions Database Releases • Select Language
Extension name: Select Language
Author: Steve
Extension description: Extension Name: phpBB Select Language
Author: Steve
Extension Version: 1.0.0
Requirements:
Extension Description: Creates a dropdown list in the navbar, allowing users to choose and use installed language packs.
Updates registered user's language on input.
Updates a guest's language on input.
Note: More than one language pack needs to be installed for this extension to be active.
Extension version: 1.0.0
Tested on phpBB version: 3.3.13
Download file: steve-langselect-1.0.0.zip
File size: 9.94 KiB
Source: [url]https://www.phpbb.com/community/viewtopic.php?p=16040032#p16040032
