Question Questionsmchat on the portal
Re: mchat on the portal
Then you have other issues as the mchat portal works fine still.
rammstein
Post by rammstein »
Good morning all
the forum no longer works I crashed the forum
I had to reinstall the forum I only have 3 extensions, it's a test forum
rammstein
    Windows 10 Edge
Re: mchat sur le portail
Post by rammstein »
I installed the b3pmchat extension I always have a blank page no longer possible to go to the forum
That issue is some thing else pls update all exts you have installed.
rammstein
    Windows 10 Edge
Post by rammstein »
I only have 3 extensions install the mchat the portal and b3pmchat that's all
board3/portal 2..1.0
dmzx/mchat 2.1.4
talonos/b3pmchat 2.1.0
phpbb3.3.1
Maclobster
Post by Maclobster »
rammstein wrote: Sep 16th, '20, 19:13 Good evening
I have the board3 I have installed the mchat version 2.1.4 I want to put the mchat in the board with talonos / b3pmchat once I have installed talonos / b3pmchat extension no longer possible to go in acp
my versions
chat 2.1.4
phpbb 3.3.1
php 7.2
thank you
Have same install and works fine here, only different is phpbb version
Can you try to set it on php 7.3?
“A man searching for the Lost Paradise, can seem a fool to those who never sought the other world.”
-JM
rammstein
    Windows 10 Edge
Post by rammstein »
I switched to php 7.3 every day the same
miri4ever
Post by miri4ever »
What kind of language did you use ? It got the same white page inside another extension if there was an error inside translation files. I know this should be working fine, but you might added some translations other as english to the portal block extension.
rammstein
    Windows 10 Edge
Post by rammstein »
I put in French that doesn't change anything every day the error
Upload your language files pls.
rammstein
    Windows 10 Edge
Post by rammstein »
Here are my language files
when I install talonos / b3pmchat extension all immediately I have my white acp no longer possible to come back
Pls put them in a zip file your rar file is broken.
rammstein
    Windows 10 Edge
Post by rammstein »
I send you all the file with my theme
Midway
Post by Midway »
Your language file is converted to mac format this is not good
Pls no rar folder zip only as i am a linux user rar are blocked.
