Various modifications for phpBB3Reason for editing post required
Snippets for phpBB3
    unknown unknown
Force user's to fill out the reason for editing a post.
Open /posting.php
Find This may be a partial find and not the whole line (spaces may differ)
if (sizeof($message_parser->warn_msg))
        $error[] = implode('<br />', $message_parser->warn_msg);
// When editing, a reason is mandatory for all users
        if( $mode== 'edit'&& !$post_data['post_edit_reason'] )
        $error[]= 'Edit reason is required!';
(around line 666):
$post_data['post_edit_reason']   = (!empty($_POST['edit_reason']) && $mode == 'edit' && $auth->acl_get('m_edit', $forum_id)) ? utf8_normalize_nfc(request_var('edit_reason', '', true)) : '';
$post_data['post_edit_reason']   = (!empty($_POST['edit_reason']) && $mode == 'edit'/* && $auth->acl_get('m_edit', $forum_id)*/) ? utf8_normalize_nfc(request_var('edit_reason', '', true)) : '';
(around like 1448):
'S_EDIT_REASON'            => ($mode == 'edit' && $auth->acl_get('m_edit', $forum_id)) ? true : false,
'S_EDIT_REASON'            => ($mode == 'edit'/* && $auth->acl_get('m_edit', $forum_id)*/) ? true : false,
Raheem
Re: Reason for editing post required
Post by Raheem »
Better than forcing him write reason, you can make it like in vBulletin if member edited his post without write the reason it will be:
And if he wite the reason it will be like: Last edited by USERNAME; 10-12-2009 at 20:35. Reason: REASON!
Did you look at the date of this topic ?
Raheem
Post by Raheem »
Yes what's the problem then?
I did not like this modification when you were using it on your site awhile back. But I did love entering in "I don't need a reason fool!" :rolling:
Sniper_E wrote: Feb 13th, '17, 22:58 I did not like this modification when you were using it on your site awhile back. But I did love entering in "I don't need a reason fool!" :rolling:
:rolling:
Might add it back but allow admins to carry on with out a reason.
martin wrote: Dec 11th, '17, 20:44 Might add it back but allow admins to carry on with out a reason.
You might give me another reason to call you a fool! :rolling:
Got it working on 3.2.1 :rolling:
I was afraid that might happen. :rolling:
Sniper_E wrote: Dec 12th, '17, 00:21 I was afraid that might happen. :rolling:
:rolling:
Edits are in my admin section :rolling: Dont steal them Ed :rolling:
